Post Wysłano: 27 lip 2010, 22:55
Witam!!
Piszę test dla angielskiego pracodawcy i natrafiłem się na takie pytanie jak: "Nazwij podaj kolory dwóch przewodów sprzęgających ciągnik z naczepą". I dokładnie poszczególnie do czego służą.
Tak to pytanie brzmi po angielsku.
"Name and give the colours of two airlines used in tractor unit"
a.___________ b. _________
Bardzo dziękuje za odpowiedzi.
Paweł
Post Wysłano: 27 lip 2010, 22:59
GG: 5839699
search.php?keywords=%C5%BC%C3%B3%C5%82t ... mit=Szukaj
'..biorę co los da, życia made in Polska
to jest moje miejsce bo kocham to miejsce ...'
/IRC
http://www.youtube.com/watch?v=pkwvifYw ... AYxJoN4pXc
Post Wysłano: 28 lip 2010, 20:43
Trailer Air Lines Every combination vehicle has two air lines. These lines are the service line and the emergency line. They run between each vehicle, such as tractor to trailer, trailer to dolly, and dolly to second trailer.
SERVICE AIR LINES.— The service line carries air that is controlled by the foot brake or the trailer hand brake. Depending on how hard the foot brake is engaged, the pressure in the service line will similarly change. The service line is connected to relay valve(s) on the trailer to apply more or less pressure to the trailer brakes. As pressure increases in the service line, the relay valve opens and sends air pressure from the trailer air tanks to the trailer brake chambers, thus applying the trailer brakes.
EMERGENCY AIR LINES.— The emergency line has two purposes. First, it supplies air to the trailer air tanks. Second, the emergency line controls the emergency brakes on the combination vehicle. Loss of air pressure in the emergency line causes the trailer emergency brakes to activate. The pressure loss could be caused by a trailer breaking loose and tearing apart the emergency air hose. The loss could also be the result of a hose, metal tubing, or other parts breaking and causing an air leak. When the emergency line loses pressure, it also causes the tractor protection valve to close, causing the air supply knob to pop out.
Emergency lines such as hoses couplers, and other parts, have a red covering. The red covering allows you to separate the emergency lines from the service lines which have a yellow covering.
Dodatkowo na obrazku masz jakie laczniki stosujemy w UK inne niz w Europie niewiem czy lepsze napewno inne :wink:
Na zdjeciu jest system rolniczy odwrotny przyczepa ma przewody a traktor gniazda w ciezarowce oczywiscie masz odwrotnie ciagnik ma przewody a naczepa gniazda :> ale kolory i laczniki takie same.
I definitely have got Diesel In My Veins
Certificate of Professional Competence in National and International Road Haulage
Post Wysłano: 01 sie 2010, 10:49
Trochę dziwne nazewnictwo, biorąc pod uwagę, że często (w Volvie zawsze) są naklejki na wsporniku gniazd elektrycznych i przewodów powietrznych opatrzone hasłami:
Żółty - CONTROL
Czerwony - SUPPLY
Post Wysłano: 01 sie 2010, 11:06
Żółty - CONTROL
Czerwony - SUPPLY
koproselek pytal o nazewnictwo brytyjskie :wink: a to niezawsze to samo co angielskie np w Ameryce czesto zamiast oznaczac kabel service na zolto robia to kolorem niebieskim :U
Wiele rzeczy jest u nas innych np kierownica po innej stronie :>
Post Wysłano: 01 sie 2010, 11:12
Na temat kierownicy to się nie wypowiadam bo nie zauważyłem ;) ale już za pierwszym razem stojąc na "ichnim serwisie" widziałem, że naczepy posiadają inny system gniazd pneumatycznych, skądinąd eliminujący pomyłkę w podłączaniu przewodów.
